Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Coolant Block Plug ???
Old 06-22-2010, 03:57 PM
Jordan31's Avatar
Jordan31
Jordan31 is offline
Thanks for the quick reply!
Did you have any problem getting air out of the system?
Like I mentioned before, I tried to drain mine, but not enough came out, so I figured i'd fill what I drained with water temporarily, and do the job the correct way later on... But every day after arriving at work, I have to pour some of my water bottle to get the reservoir back to the full mark.
Is there a bleed valve somewhere maybe? or a better way of getting the air out?
thanks
-jordan
Old 06-22-2010, 07:39 PM
2fords2's Avatar
2fords2
2fords2 is offline
Getting the air out is a bear. No bleeder valve. Just add water or coolant until the recovery tank is full. I kept a gallon of water in the vehicle just for this purpose.
Old 06-22-2010, 09:27 PM
wptski's Avatar
wptski
wptski is offline
Not sure when it started but the '09s have a bleeder valve.
Old 12-09-2011, 02:02 PM
RandyBryant's Avatar
RandyBryant
RandyBryant is offline
Drain Plug block heater
Is it possible to install a block heater in this drain plug hole.
If so, any suggestion on brands/part numbers?
Rangerr86
1983 - 2012 Ranger & B-Series
12-05-2014 01:03 AM
blueeyedfordguy
General Diesel Discussion
12-16-2013 02:22 PM
daveya48187
12-03-2011 12:47 PM
Diesel Don 57
09-21-2010 05:51 PM
Brians97F250Crew
02-16-2010 09:50 PM
Quick Reply: Coolant Block Plug ???
