Engine block coolant drain plug ???
Old Dec 3, 2011 | 12:25 PM
daveya48187's Avatar
daveya48187
Ford Escape 6 cylinder - 100,00 miles. want to flush and change the coolant. Cannot unscrew the engine block drain plug using a 14 mm allen hex bit. Afraid of damaging the block, maybe cracking it. I tried turning the plug with my 1/2" torque wrench up to 130 ft. lbs. torque and it would not budge. Am afraid to use more or to put a cheater on the torque wrench. If something goes wrong the engine becomes scrap. Anyone ever run into this? What's the solution?
Old Dec 3, 2011 | 12:47 PM
rikard's Avatar
rikard
There are flush kits available that install on the heater hose which will allow you to flush the system.
regards
rikard
19tanker
23
Jan 20, 2014 08:54 AM
nitro3421
Jan 12, 2011 07:26 AM
Ned Nimrod
1997 - 2003 F150
Dec 26, 2006 10:10 AM
jasond5150
Jan 12, 2005 08:04 PM
FARM69
Dec 5, 2004 03:23 PM
