Gauges
Old Apr 5, 2002 | 02:47 PM
Route66's Avatar
Route66
Gauges
Has anyone installed the BD X-Monitor? Has a digital pyro, boost and trans temp all displayed on one digital monitor. It's from BD-Power and runs about $430.00 plus the cost of installing. What do you think?
Old Apr 6, 2002 | 10:37 AM
ruthless's Avatar
ruthless
Gauges
I use the VDO boost and the VDO pyro. I have them mounted in the flat spots on the dash on either side of the steering colum. They look like Ford installed them. They have the same faces as the stock instument cluster, the needles are the same color, and they back light up green just like the stock gauges do. It took me about four hours to cut the holes and drill the manifold and do the wiring. No "A" pillar for me. I could not be happier. I think the Pyro was about $220.00 and the Boost was about $54.00. Seeing it all happen,
well you know.
Old Apr 7, 2002 | 10:42 AM
greengoose's Avatar
greengoose
Gauges
Ruthless,
Do you have any pictures of your gauge set up? Im trying to deceide between the A-pillar or the flat spots to the left and right of the steering wheel.
-Bryan
Old Apr 7, 2002 | 06:30 PM
ruthless's Avatar
ruthless
Gauges
You know, I have a digital camera and I am to stupid to figure outr how the thing works. Even the directions do not make sense. I would like to have a camera that I can share the pictures with that is user friendly.
With that said, everyone who has seen my gauge placement thinks it came that way. I take that as a compliment.
It is fairly straight forward. The "A" pillar is the way most guy's go. I would rather look at my gauges, than have my gauges look at me. Those flat spots are perfect. The one on the left has more stuff behind it than the one on the right.
I found the center of both flat areas and marked them. I then put a caliper to the diameter of the gauges and divided that number by half.Then I took that number and transfered it to a set of dividers (a compass)and scribed the size of the gauges onto the flat areas, Pyro on the left, boost on the right. Here's the hard part.I got out my drill and drilled a half inch hole in two places of my brand new perfectly good dash of my very expensive truck that I will be paying for a long time. Now the trick. I used my dremel tool. I put a sanding barrel on that tool and very carfully ground away the material rifgt up to my scribe lines. I left enough material to make an interferance fit so the gauges just press in and push out, no back clamping involved. I daisey chained the back lighting and tied into the dimmer wire that is located behind the light switch. Daisey chaine the ground to the ground termination that happens to be right there on the left. Picked up switched power from the fuse box, also right there. pulled my wire through the factory grommets in the firewall, drilled and tapped the exhaust manifold in place. Hooked it all together after tapping into my boost line, and it was done. I went REAL slow and carefull, no mistakes allowed, and it took me four hours. And now it is done and it works and looks great.
So far I have put a 3" Jack-It leveling kit on the front and an Add-A-Leaf on the rear,Bilsteins all around, a "Rauncho" steering stabilzer,
A Volant Cool Air Induction System, RACOR CCV Intercooler mod, Quiet ignition key,VDO pyro and boost,Silvania Silver Star bulb replacment in driving lights and headlights,SCMT,285/70R16 Dueler AT's, Snug top "EXPO", Bed rug,Ford factory molded mudflaps, Next I am going to put a Bully Dog S/S 4" down pipe and tie it into a S/S 4" Magna Flow exhaust system that terminates with the polished S/S 5" exhaust tip. My truck runs good, could not be happier.
Old Apr 17, 2002 | 12:52 AM
LW555's Avatar
LW555
Post Gauges
Old Apr 18, 2002 | 06:04 PM
rvfiver's Avatar
rvfiver
Gauges
I have seen the setup on the BD web site. Would be interested in any info you discover about this system. Was thinking of getting it myself but wanted to wait until I have spoken to someone who has it in place.
rackhound
Jul 8, 2011 09:43 PM
jeffdoerr
May 14, 2010 10:50 AM
afinepoint
Sep 5, 2008 04:41 PM
2000psd
Oct 7, 2004 08:23 PM
xer
Apr 16, 2004 06:28 PM
