Transmission temp on 2013 Super duty
So this is my first truck that I can actually view my transmission temp and i was wondering whats the average temperature I should be at. I often drive around 80 to 85 mph with no significant weight in or on the truck and at those speeds my transmissions between 204 and 206 degrees. Does that sound pretty normal? While were at it whats the average oil temps for those speeds?
First, Welcome to the 6.7 forums. I love my 2013. Running those speeds your tranny is at normal temps. The engine oil temp will also run about 205 deg. Make sure when you stop after running high speed you idle the engine till the oil temp gets about 195 before you shut it off. This is to cool down the turbo bearings. Have fun, be safe and let us know how you like the truck.
I was under the impression that it wasn't really designed to run hotter but that the temp sender was in the valve body which tends to run at a higher temp and pan temps are still in the 160-170ish range.
Your impression is wrong. There is a thermostat in the trans and it's setting will cause the trans to run about 195-205F. The temp sender has been in the solenoid body/valve body area since the first E4OD in 1988.
My experience has mostly been in the older GM's where guys were putting trans temp senders in the pan and looking for 160-170ish temps.
What are the temps at the main points in the trans - pan, valve body (obviously 195ish), thermostat, torque converter, and any other points that may be of interest.
Educate me!
One thing I have noticed in mine is that the factory gauge will climb in temp until about 140ish (about 40% of the sweep of the gauge) and then it will stop yet the temps on my Edge CTS will continue to climb to the 195ish area. Is that how it is designed, how do they do that, do I have a malfunction somewhere?
Anywhere from 25 degrees hotter to 50 degrees colder than the test port.
That's about right.
About 195.
Anywhere from about the test port temp up to around 300F is normal.
It's done with software. The instrument cluster computer reads the trans temp and decides where to place the needle.
Exactly!
The gauges in the trucks are really nothing more than idiot lights. Not accurate at all and designed to show a normal range till it gets really hot. I think it was designed that way to cut down on concerns from customers that there was something wrong when really there was not.
Actually, it does seem even the engine temp and trans temp gauges are reasonably inline with actual readings. But I do agree the goal of the "damped" gauges is to make the customer not worry.
RCsanjose
07-23-2003 11:20 AM
