1978 - 1996 Big Bronco
Buzz when parked?
Old May 7, 2004 | 10:08 AM
ubermich's Avatar
ubermich
Buzz when parked?
When I park and get out, something in the back (near/in the gas tank??) keeps making a noise... something between a whir and a buzz... Does it for about a minute then stops...
Is it my fuel pump or something else? You guys with your lists of repairs have me nervous now
Old May 7, 2004 | 10:09 AM
ANdrewdrice's Avatar
ANdrewdrice
might be the filter, could be the pump, maybe you got a bee stuck in the gas tank.
Old May 7, 2004 | 11:28 AM
ubermich's Avatar
ubermich
Now it's not stopping after a minute or two... I went to the bank (to get money for parts) and 5-10 min later when I came out it was still doing it... Should I be worried/afraid?
Old May 7, 2004 | 01:01 PM
tigerhawk_212's Avatar
tigerhawk_212
try replacing your fuel pump relay. It is probably bad and is not cutting off your fuel pump which is making the sound.
Old May 8, 2004 | 08:35 AM
ubermich's Avatar
ubermich
where is the fuel pump relay? So far all I've found is "under the dash"... is there anything with more detail? I have a '90 xlt btw.
Old May 8, 2004 | 08:40 AM
tigerhawk_212
it should be located right behind your air filter box. It is connected under a black plastic rectangular piece. It should say fuel pump on it.
Old May 8, 2004 | 09:33 AM
ubermich's Avatar
ubermich
Got it! Problem solved (though I did break the clip that holds the relay in the box with the other relays by accident). Thanks!
Old May 8, 2004 | 10:17 AM
tigerhawk_212
ure welcome. those relays are sort-of tricky to get off
