I have a question for all you genius's.. My friend was telling me about this electronic system to put in your truck.. I have a 2000 Ford F-250 Super Duty Powerstroke Limited 2000... What it does is theres a key pad in your truck and it has a bunch of different setting. You can smoke your tires or run like fast quarter miles. He pretty much explained it as putting a supercharger in your truck.. Because you put turbo pipes and stuff in it.. I was just wondering if anyone knew what it was called and maybe where I could find one..
Thanks
FordMan250PS
I found out what I think it is called.. Correct me if I'm wrong but I think he called it a six shooter.. Do you know if that name is correct or maybe if I could find one.
That's a Banks six gun. www.bankspower.com. You'll save a bunch of money and get similar performance if you use the Motorhaven link johnsdiesel provided. JMO
I agree with cookie88, don't waste your money on the Banks stuff. You can get the same, if not better, performance by putting together your own "kit." Check out Motorhaven, they usually have really good prices.
BTW, the supercharger comparison is off base. You already have a turbocharger, which performs a similar function as a supercharger.
