Man do I have issues!
Old May 6, 2004 | 09:41 PM
KYHossF150's Avatar
KYHossF150
Quick questions:
I posted a while back, and didn't really get some satisfaction on this issue:
The front tank on my 96 f150 gets around 20-21 mpg, but my back tank only gets 11-12 mpg. I have NO leaks. I have no pumping from one to the other. When on the back tank, the truck is obviously running rough, as the engine bucks and jumps and misses. I need causes, and solutions.
I have heard that there's a low pressure pump in tank and a high pressure pump on the frame. Is this correct, and could the low pressure pumping too much be the problem? I need some help, because gas is up to $2 a gallon in my area, and I drive 120 miles a day.
I've checked for sugaring or contaminants as directed before, and found nothing. Help!
Old May 7, 2004 | 12:23 AM
robduval's Avatar
robduval
try and put a fuel pressure guage to it then switch the tanks and check the readings. it sounds like a fuel pump problem. as for the two fuel pump thing last time i put a filter (on the frame rail) and a pump in the rear tank of my buddies 96 f-150 i didn't see another pump on the frame rail, only a divider solinoid. what your truck is doing sounds like what his was doing and the rear pump replacement fixed it.
Old May 9, 2004 | 04:36 PM
KYHossF150's Avatar
KYHossF150
I kind of hoped it wasn't a pump in the tank problem. Aren't those pretty expensive and a pain in the butt to replace? I've thought about plumbing the back with a hose mounted low on the tank to the front tank, with a check valve to stop back flow. Essentially, I hope to have one big tank, but two fill up points. Can I do this without leakage?
Old May 9, 2004 | 11:46 PM
robduval's Avatar
robduval
if my memory serves me right it realy wasn't that bad. the pump was like 80 bucks and as far as changing the pump just hose the bolts with a good penatraiting oil for a couple of days before you change it. MAKE SHURE you run that tank close to empty before droping it the job is a lot eaiser with an empty tank. as for linking the tanks i don't see why not but it may be a lot more of a hassle than you think. to save your self the headace try putting a fuel pressure guage to it just to be shure.
flytwins
16
Jan 15, 2018 10:51 PM
kaz442
Jul 24, 2012 06:01 PM
Solomon_Man
31
Aug 26, 2010 07:02 PM
energizedsbs
Jun 7, 2010 02:26 PM
