97 powerstroke trans. problem
Old May 5, 2004 | 10:27 PM
krzyk26's Avatar
krzyk26
I just bought my powerstroke 23 hours after buying I noticed a small transmission leak. While stuck in traffic the small leak started gushing. The truck has a Banks ottomind installed it would shift real hard with it in and normal with it out. Banks said there chip doesn't have anything to do with the transmission.
After replacing the trans. I took the chip out I miss the power but I dont want to have to replace another trans. I found out this is th fourth trans. The truck has only 109,000 miles. I would like to know if anyone has had any similar problems and if there could be something else destroying the transmission. It is long wheel base crew cab 4x4 w/ 6 inch lift 410 gears and 36x14.5x16.5 tires. Any info would be appreciated. Thanks
Old May 5, 2004 | 10:30 PM
Fire Rooster's Avatar
Fire Rooster
I would check to see if the lift was done properly and that all the correct angles are matched up as to not put undue stress on the entire drive train.
Fire rooster
Old May 5, 2004 | 10:37 PM
krzyk26's Avatar
krzyk26
OK thanks that was something I was tossing around but hearing it from someone else I will have it checked.
funzjb1
Feb 7, 2014 03:46 PM
logcruiser
16
Jul 13, 2013 10:36 PM
paintball_pro
34
Nov 5, 2007 02:02 PM
cochran226
Jun 18, 2007 05:37 PM
MR.DAVE
Nov 23, 2006 08:08 AM
