Mass Airflow Sensor bad?
Old May 5, 2004 | 09:22 PM
jwh's Avatar
jwh
Greetings all. I have a '94 Explorer Automatic Trans, 105,300 miles. All of a sudden it started running terrible. The check engine light came on, the exhaust smells awful and it's spewing carbon out the tailpipe. I'm getting a code 157 - "Mass Air Flow signal low or grounded" I've tried cleaning the filaments with no help. Anyody got any ideas other than changing the Mass Airflow Sensor?
Thanks all.
Old May 5, 2004 | 09:55 PM
mrshorty's Avatar
mrshorty
Computer codes point to problems in a circuit, not necessarily at any individual parts in that circuit. Problem might be a bad sensor, but it could just as easily be a bad connection between the computer and the MAF, a bad reference voltage, a bad excitation voltage to the MAF, Air getting in through another route other than the MAF (such as if the intake tube were disconnected).
1st question: Is this a continuous memory code? If so, did you get pass codes for both the KOEO hard faults and the KOER test?
If this is the only code, then start by carefully inspecting the wiring. Make sure there are no obvious breaks/bad connections/etc.
Then, get a wiring diagram (so you know what wire is what) and make sure the MAF is getting battery voltage at the appropriate leads. Make sure the Vref has ~5 volts. This is where a good pinpoint or circuit test comes in handy.
Old May 5, 2004 | 10:06 PM
jwh's Avatar
jwh
Thanks Mr. Shorty. The 157 code comes in from both the key on engine off and engine running test. I'm also getting a "998 Did not pass KOEO Test."
Thanks for the tip on voltages, I will check them tomorrow.
Old May 5, 2004 | 11:32 PM
mrshorty's Avatar
mrshorty
Is the KOEO 157 a hard fault code or a continuous memory code?
Old May 6, 2004 | 04:41 PM
jwh's Avatar
jwh
157 Comes in as a hard fault and with the engine running.
I checked the wires at the connector......
heres what i get....
A Red 12 Volts
B Black / White stripe Ground (checked with ohms to neg. battery post, also measured 12 V between A & B)
C Tan / Light Blue stripe 5.97 Volts (Exciter?)
D Light Blue / Red Stripe O Volts
Thanks alot for your help...
Old May 6, 2004 | 08:08 PM
91ford_ranger's Avatar
91ford_ranger
A mechanic just told me today to check MAF by tapping on it at idle. If the engine starts misfiring maf is likely the problem. He also said it didn't work in 100% of all cases. (like mine). Cheap to try.
Old May 7, 2004 | 10:41 AM
mrshorty's Avatar
mrshorty
I can't remember for sure, but C and D don't look right. As I recall, the voltage between the MAF return pin and ground should be ~0.6 V at idle, and should increase with increased throttle opening/engine speed. Could indicate a bad MAF, but I'd get a hold of a proper circuit test before coming to that conclusion. They can often be had in Mitchell manuals in the reference section of many libraries.
Old May 7, 2004 | 04:19 PM
jwh's Avatar
jwh
I tried tapping on it when I got to work this morning, on my way home it actually ran OK (no check engine light) for a few miles. The voltage readings I got where with the key on , engine off, and the connector unplugged so I think they make sense. I will try later to get them with everything running.
Thanks again for the help!!!
Old May 9, 2004 | 08:10 PM
jwh's Avatar
jwh
It's Fixed!
I broke down for a new (actually reman'ed) Mass Airflow Sensor yesterday. So far it's working great! Thanks again for your help guys.
TracyN
Jan 18, 2016 01:43 PM
Medic27
Oct 21, 2004 08:41 AM
dumpsterdan
3.8 & 4.2L V6
Sep 20, 2004 02:28 PM
84Maztang
May 31, 2004 04:44 PM
tomucen
Aerostar
Nov 12, 2002 08:05 AM
