Oil & Lubrication
Which Tranny Fluid??!!
Old May 5, 2004 | 09:07 PM
live2hunt's Avatar
live2hunt
'96 full sized Broncho with 5.4L. Not sure which auto tranny is in it.
Took it to Jiffy Lube yesterday for their $90.00 tranny flush service. I just noticed that Mercon is recomended (on the dip stick and in my Haynes manual). The invoice says they put Dextron III in it. Will this be, or is this a problem?
Old May 5, 2004 | 09:59 PM
rusty70f100's Avatar
rusty70f100
Go back and ask. They probably put a dual rated fluid in it, which should be fine. They probably do a majority GM work, and therefore have it listed as Dexron in their computer. It'd be kind of hard for 'em to ring it up differently. But yeah, go back and ask.
Old May 5, 2004 | 10:09 PM
Rockledge's Avatar
Rockledge
I think your Bronco has the E4OD tranny in it?
If so, then you have to think that they put in Pennzoil's Dexron III ATF, and that wouldn't be a problem, because it meets and exceeds Ford's Mercon specs.
Old May 5, 2004 | 10:11 PM
KenB's Avatar
KenB
When in doubt, get all the facts/details.
Either go to a dealer or write down your entire VIN and call a Ford dealer.
They'll tell you exactly which tranny you've got and which fluids are usable in it.
Old May 5, 2004 | 10:22 PM
live2hunt's Avatar
live2hunt
Excellent advice from all of you. Thanking you . . .
Old May 6, 2004 | 02:09 AM
Stab's Avatar
Stab
Dexton III/Mercon is the same fluid. I have a 94 Crown Vic that calls for the same fluid, no problem.
Are you getting transmission shudder?
If so let me know I have a instant cure.
Old May 6, 2004 | 02:13 AM
Stab's Avatar
Stab
Dude if you have a 96 Bronco with a 5.4 you have a vehicle that has had a engine swap(99.9999999% sure this is not the case). Please don't take offense but you need to learn a little more about your truck to properly take of it.
The modular engines were NEVER installed in the Bronco. Either a 5.0 or a 5.8 and possibly the inline 6 but not a 5.4.
Old May 6, 2004 | 07:33 AM
live2hunt's Avatar
live2hunt
5.8L I'll never get used to metric engine sizes!!! IT'S A 351 DAMN IT! Sorry . . . I had a writ of fage.
Good advice all . . . Thank God for FTE, He must be a Ford man.
Old May 6, 2004 | 10:30 AM
Stab's Avatar
Stab
Boy my earlier post sounded snotty as he11. Didn't mean it that way. The Mercon/dextronIII will be just fine. Watch out for the jiffylube idiots. Double check everything when they are done.
skillykat
Jan 15, 2015 12:47 AM
mgates1964
Aug 8, 2014 10:30 AM
wildcard221
1978 - 1996 Big Bronco
Aug 3, 2014 05:48 PM
96str8sixford
Mar 19, 2009 05:13 AM
d0n_3d
1983 - 2012 Ranger & B-Series
Jan 17, 2004 12:00 AM
