constant backfire problems
Old May 5, 2004 | 08:11 PM
wrenchturner's Avatar
wrenchturner
Angry constant backfire problems
I have an 81 f150 4wd 4spd. It almost always back fires if i give it more than a quarter pedal of gas. I put in new plugs, wires cap rotor, donut gasket. ANy ideas?
Old May 5, 2004 | 08:17 PM
King Triton's Avatar
King Triton
It could be a lot of different things,timing,sticky valve,vac advance in dist,how did your old plugs look,any of them oily or covered with carbon?
Old May 5, 2004 | 08:25 PM
Slade901's Avatar
Slade901
Check for exhaust back pressure. Your cat maybe partially clogged.
Old May 5, 2004 | 08:26 PM
bremen242's Avatar
bremen242
try taking the belt off of the smog pump.. Sometimes one of those valves fail and cause back firing..
Old May 6, 2004 | 06:06 AM
wrenchturner
Thanks for the help. pulled the belt off worked great. now what did the screw on the carb do that my friend turned trying to make it stop? It must be cold idle or something.
Old May 6, 2004 | 06:25 AM
bremen242's Avatar
bremen242
It more than likely adjusted the idle mixture.... the easiest way to re adjust it is to turn it in all the way and back it out until you reach the lowest idle speed...
Old May 6, 2004 | 09:37 AM
Big Orn's Avatar
Big Orn
Is it a Holley carb? Power Valve failure will make it backfire through the carb.
It is through the carb, right?
Old May 6, 2004 | 11:22 PM
fordeverpower's Avatar
fordeverpower
also check the timing. Take a look at total timing as well!
Old May 7, 2004 | 06:49 AM
bremen242's Avatar
bremen242
You guys did notice he said "Thanks for the help. pulled the belt off worked great. now what did the screw on the carb do that my friend turned trying to make it stop? It must be cold idle or something."
joeskeeter
Feb 21, 2008 10:23 AM
nobull4x4
Jan 23, 2005 03:55 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
4x4x4x4
Sep 30, 2002 03:55 PM
stoab
Sep 10, 2002 01:13 AM
