Haunted '98 EB
Old May 5, 2004 | 08:05 PM
BillF250P's Avatar
BillF250P
Haunted '98 EB
My wife has been saying that the truck is unlocked every time she comes out of work, and she's sure she locked it. Last night, as I was sitting in the garage, kicking back with a beer, and admiring my recently painted '79 bed, I noticed the Explorer in the next bay, making door locking noises every 5 or 10 mins or so. I checked the remote- normal. I locked the doors, and 5 mins later they opened by themselves. Then they would click every couple of minutes. I took a relay out of the box over the left rear wheelwell. That cured it, but the only door lock that works now is the driver's, and only from the inside switch. I'm kinda leaning toward a broken wire going into the drivers door, but I haven't had time to get near it yet. I remember seeing a post like this before, but can't find it now. I'd really appreciate it if anyone has any insight into this.. Thanx.....Bill....
Old May 5, 2004 | 08:10 PM
HomerWinzlow's Avatar
HomerWinzlow
If you have a switch at the left rear quarter panel that allows you to work the locks from the tailgate area, it has been a common occurance for that switch to get contaminated with water and cause lock cycling. I would pull that switch and inspect it and the connector closely for contamination/shorting. Also some reports of water intrusion in the lock switches on the door locks of vehicles with alarm system have been known to cause lock cycling as well. Also I had a couple where a water leak caused pooling of water under the rear seat area where the wiring looms pass and into the wiring loom channels under the scuffplates and caused wiring shorts.
Old May 5, 2004 | 08:56 PM
BillF250P's Avatar
BillF250P
Thank You, HomerWinzlow... I didn't think of a leak, but they design these door switches for maximum water exposure. Last year, we went roundy-round with my son's '98 F-150. Replaced GEM module, air bag module, 3 relays under dash, and mirror switch. Also had to re-seal windshield. I think I'm going to join FTE- I've freeloaded here long enough, and everything we own wears the Blue Oval. Thanx again...Bill...
Old May 5, 2004 | 09:00 PM
HomerWinzlow
Yes, my 2000 Expedition had the windsheild resealed 3 times, 2 fuse boxes and 2 gem modules. They finally had to pull the windshield out and replace the seal completely to get the water leak stopped. Its been a problem for years.
Old Sep 8, 2004 | 10:49 AM
96explorer5.0v8's Avatar
96explorer5.0v8
haunted door locks
I had the same problem with my '96 AWD and it turned out to be the switches on the door lock cylinders. You could try blasting the lock cylinders with contact cleaner and really working them with the key but the real fix is opening the door panels and just unplugging the switches. Do all three; front doors as well as the hatch and the ghost goes away! The switches are only there to allow you to unlock all the doors at once by cycling the key twice; a minimal feature at best.
Old Sep 8, 2004 | 12:02 PM
1081's Avatar
1081
Moisture is probably the culprit but if that doesn't work, I have had this symptom when the battery had a weak cell or the voltage would periodically drop momentarily causing the locks to lock and unlock...mine could have just been a fluke though.
crankbait321
Electrical Systems/Wiring
Feb 20, 2022 08:13 PM
hturner12
Apr 16, 2016 11:01 AM
dcchadwick
Mar 6, 2016 10:10 PM
hivoltj
Mar 9, 2015 12:05 PM
TYZ78F150
Sep 4, 2009 08:41 PM
