351C break in?
Old May 5, 2004 | 06:37 PM
67fastbackfreak's Avatar
67fastbackfreak
Question 351C break in?
i just bought a car with a 351 and the engine is brand new. what is the best way to break it in? how often are oil changes needed, and what kind of oil is best (only because ive heard synthetic blends are bad for brand new engines). any information is appreciated
thanks
Old May 5, 2004 | 10:03 PM
1979ford's Avatar
1979ford
I have used the 100 mile approach. After the first 100 miles i change the oil after an overhaul, glitter in the oil is normal but flakes are bad news. I would probably use 10W-30 for the first one or two oil changes. Then after that you can use your synthetic blend. Break it in like your going to drive it.
Old May 6, 2004 | 04:53 PM
thatdude's Avatar
thatdude
I have always changed the initial oil right after starting the moter for the first time, letting it warm up, setting the timing, adjusting the carb etc. then after 100mi and then every 1000 for ever.
I do it this way because of the assembly lube and all of the "glitter" 1979ford mentioned, the glitter is normal, but its abrasive.
Oil is cheap, a new motor aint. There is no such thing as changing it too often.
Old May 6, 2004 | 04:56 PM
TowinBob's Avatar
TowinBob
If it has a new cam it needs to be broke in for 20 minutes not dropping below 2000 rpm.
Old May 6, 2004 | 05:03 PM
thatdude's Avatar
thatdude
Oh I almost forgot.
If you drive like me (maniac), give it a couple hundred before beating it to death, after a rebuild all them parts have got to get to know each other again before they are comfortable going to red line.
Just my opinions here.
Old May 7, 2004 | 05:04 PM
thatdude's Avatar
thatdude
Thumbs up
I forgot to mention that, thanks bob.
351Cleveland C4
Jun 30, 2013 02:04 PM
RIKIL
15
Aug 22, 2011 06:09 PM
lincolnrig
Jun 25, 2011 06:41 AM
E30tdf
Feb 2, 2008 01:02 PM
ATC_250SX
16
Dec 20, 2004 09:44 AM
