Ranger running poorly
Old May 5, 2004 | 11:31 AM
newtattoobob1's Avatar
newtattoobob1
I have a 93 2wd ranger with a 3.0 and manual transmission. Everytime I start it when the engine is cold it will idle fine but the first few times I try to take off it boggs down and wants to stall, sometimes it does stall and is hard to get started again. After it warms up it runs fine. I have tried new plugs, wires, cap and rotor, new fuel filter and air filter and cleaning the MAF, but nothing has seemed to help. I took it to the local ford dealer awile back and they did a fuel system service where they clean the injectors. It helped for about a week and then it started acting up again. Anybody got any ideas what I could try next? Thanks Rob
Old May 5, 2004 | 12:07 PM
cary200's Avatar
cary200
Did they change the fuel filter? How long has that been? I'd start w/ the simple stuff. I have 00 2.5L 5 spd that ran alot better after replacing the fuel filter (sluggish at 65pmh to the point of pinging). My old filter had dirt in it.
My second thought is your EGR system or vacuum lines.
Just a suggestion
Old May 5, 2004 | 12:54 PM
87 XLT's Avatar
87 XLT
One simple thing that you can try is to remove the connector from the coolant temp sensor & see how it runs.
Old May 5, 2004 | 02:44 PM
newtattoobob1
I did change the fuel filter about 2,000 miles ago and it did not seem to make a difference. How could I check for bad vacuum lines or problems in the egr system? I will try disconnecting the coolant temp sensor, thats the one right by the thermostat housing right? Thanks Rob
Old May 5, 2004 | 03:00 PM
87 XLT's Avatar
87 XLT
Yeah, it probably is near the T-stat with a 2 wire connector. It tells the PCM whether the engine is warmed up or cold.
Old May 5, 2004 | 06:29 PM
cary200's Avatar
cary200
Sorry, my 00 truck has two of them. One for the PCM and one for the gauge. Your truck I believe is different. Check for broken vacuum lines also.
Cheers
Old May 5, 2004 | 07:22 PM
rangerkiller's Avatar
rangerkiller
If it runs poorly for the first two minutes then runs fine, just with a little loss of power, that's an ignition problem.
The ICM in a 93 advances the timing in warm-up mode, and a weak spark would cause it to idle rough during warmup and try to stall and hard start.
Try running your codes. Anything that indicates that it's running rich would serve as proof of weak spark.
If you don't/can't get codes, pull your plugs. If they're black and dry, the system is running rich.
Other things you may want to check:
Coil
fuel pump
fuel pump relay
re-gap plugs
heavier insulated spark-wires
have battery tested
ICM test
Vacuum lines
Purge canister solenoid
I'd strongly suggest getting your codes pulled in KOEO and KOER tests. You need both to pinpoint your problem.
Old May 5, 2004 | 09:09 PM
Ken00's Avatar
Ken00
See the tech info thread at the top of the forum, pulling the eec-iv codes.
Vyndrah
Oct 28, 2012 01:34 PM
Gomer Fackworth
Nov 19, 2008 08:59 PM
norg1
Bronco II
Aug 13, 2007 04:57 PM
88RangerXLT
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 27, 2005 08:32 AM
cwsdks
Jan 10, 2004 03:17 PM
