Need Help Quick
Old May 4, 2004 | 11:45 PM
MUDN69's Avatar
MUDN69
Need Help Quick
Hey,
Tonight I was driving my truck, 86 f-250 4wd, when the front left tire and wheel came off. Luckily I think the only thing I need to replace is my rotor. I did not find a real good description of how to replace the rotor in my chiltons manual and was wondering how i would go about it. The reason i need to finish it quick is because i am selling the truck day after tomorrow. SO PLEASE HELP
Old May 5, 2004 | 05:31 AM
Beast12's Avatar
Beast12
I could be wrong because I don't know how the 4wd F250s are but I think you take the tire off (seems you have already done that ) then you take your caliper off. Your rotor should just slide off, put the new one on. The loosen your bleeder screw, push your caliper back in the tighten the screw. Put your caliper back on and put yourtire back.
Those are just basic instructions. I am surprised the manual didn't have it.
-Matt
Old May 5, 2004 | 06:45 AM
Clifford II's Avatar
Clifford II
Bigger question... why did the wheel/tire come off?
Bad wheel bearings? Wheel studs break?
Scott
Old May 5, 2004 | 09:47 AM
MUDN69's Avatar
MUDN69
Well, I knew how to do it for a two wheel drive, I was thinking it may be different for a 4wd. If anyone knows lemme hear ya.
The wheel came off because all of the lug nuts stripped out. Luckily it didnt break the stud or strip the studs.
Old May 5, 2004 | 02:00 PM
USARLen's Avatar
USARLen
Chances are that you're gonna need to remove some of the locking mechanism crap to get the rotor off. It is the 2wds that come off with just taking off the caliper. It probably isn't gonna be as easy as we all hope. Best I can reccomend is to lift your truck, and start poking around. Make sure to only take one side apart at a time, the last thing you want to do is have 2 sides torn aparts, and no memory how it goes back together. At least this way you can use one side as a template if need be.
If you have to take the locking mechanism off, make sure to clean it piece by piece as you take it apart, and to lube it back up when it goes back together. Get a flat of cardboard and put the pieces on that, in the order they were removed.
Good luck, and keep us informed,
Len
P.S. Can you just change the studs while the rotor is still on the truck?
Old May 5, 2004 | 09:27 PM
MUDN69's Avatar
MUDN69
Done, It really wasnt too bad. Yes, there is a lot of crap to take apart, all the 4wd stuff. And you have to have the proper socket to get the inner nut out. Which the socket is $20 at NAPA. But other wise it aint to bad.
Old May 6, 2004 | 05:23 AM
Beast12's Avatar
Beast12
Glad you got it fixed up. Nice job!
-Matt
Artbo00
Nov 9, 2014 02:56 PM
Arps 6.9
Oct 18, 2014 12:14 PM
Wisconsinford
Feb 25, 2014 07:41 PM
brcwelding
Mar 28, 2012 03:45 PM
modeltford
Dec 20, 2007 11:10 AM
