Brake rotor replacement
Old Nov 3, 2014 | 09:54 PM
Artbo00's Avatar
Artbo00
I have a 2002 Ford Expedition and my rotors need to be replaced. I pretty much know how to replace them but I don't know if I need the standard rotor or the rotor with the hub assembly. Can someone assist?
Old Nov 3, 2014 | 11:02 PM
r2millers's Avatar
r2millers
Standard rotors on the front and hub type rotors for the rear parking brakes.
Clearly two different types for each end.
Old Nov 4, 2014 | 06:31 PM
pdqford's Avatar
pdqford
It depends. Do you have RWD or A4WD
Old Nov 8, 2014 | 12:36 PM
Artbo00's Avatar
Artbo00
Rear wheel drive.
Old Nov 9, 2014 | 02:56 PM
alloro's Avatar
alloro
Rear wheel drive.
With RWD the front rotors and hubs are the one assembly type. For 4WD the front rotors are separate from the hub. The rears are the same for either drive type. You can see it in the descriptions for yourself here: RockAuto Parts Catalog
Hank85713
Jul 5, 2019 12:57 PM
blueoval65
Aug 11, 2016 09:18 AM
AF Mezkin
Mar 15, 2007 11:59 AM
capewave
Jan 9, 2007 01:51 PM
Flabiker3
Aug 16, 2003 07:18 AM
