What tranny do I have?
Old May 4, 2004 | 01:05 AM
77traded's Avatar
77traded
I plan on doing a drain and fill with filter and gasket shortly on my f150, but I need to know what tranny I have before I go to the parts store and buy a filter. Obviously it an automatic, its in a 77 f150 with a 300 and I know it is at least a 3 speed maybe a 4 don't know since I haven't driven it much yet. What trannies should it have and how can I easily differentiate between them so that I get the right one? Also is regular mercon fluid ok, also what grade? Synthetic worth it for atf or just cause more leaks then gains? Thanks!
Old May 4, 2004 | 01:17 AM
k_krett's Avatar
k_krett
If you have a 77 with an auto, you would either have a C4 or a C6. There are identification charts all over the web, just try typing C4 or C6 and you'll see what I mean. And it will be a 3 speed auto that will start in 2nd if you put the shifter in 2, that is for traction on slippery surfaces. As far as tranny fluid goes, it would require Type F automatic transmission fluid, that is readily available at the parts stores.
Old May 4, 2004 | 01:22 AM
tetraruby300's Avatar
tetraruby300
F150? Most likely a C6. The C4's went into the F100's.
Old May 4, 2004 | 09:30 AM
oldhalftons's Avatar
oldhalftons
square pan = C4
square pan with a kickout and 17 bolts = C6
Roelito78
52
May 11, 2020 08:51 AM
77'FORD_man
May 22, 2010 02:31 PM
Texan1983
Sep 4, 2007 09:51 PM
77blueoval
Oct 24, 2003 08:52 AM
ackusackus
Sep 15, 2002 10:08 AM
