Torsion Bolt
Old May 3, 2004 | 07:17 PM
ChiefsFan's Avatar
ChiefsFan
Torsion Bolt
Where is the torsion bar bolt on an 03 XLT. I can't find it anywhere. All I am wanting to do is crank a little so I can fit 31s.
steve
Old May 3, 2004 | 10:00 PM
98xlt4x4's Avatar
98xlt4x4
Your 4x2 doesn't have torsion bars, unless it is an Edge with 4x4 suspension. You have coil springs up front. Good news is, you can usually buy 1-2" spring spacers for pretty cheap, or get a 3" spindle lift. But just you so know, a lot of people here say that they fit 31's on their 4x2 stock... Do some searching
Old May 4, 2004 | 05:10 PM
ChiefsFan's Avatar
ChiefsFan
I have heard 31s will rub a little stock so I was trying to stop that. Spring spacers are those just little spacers taht I see at autoparts stores?
Old May 5, 2004 | 01:51 AM
98xlt4x4's Avatar
98xlt4x4
http://www.suspension-components.com...ingSpacers.htm
Here's a little bit of info. They'll require an alignment after installation, possibly camber bushing or something. I'd call them and ask what else is needed.
Old May 5, 2004 | 05:37 PM
ChiefsFan's Avatar
ChiefsFan
Thanks I will look into those. Is this my easiest and cheapest option?
Old May 5, 2004 | 08:01 PM
98xlt4x4's Avatar
98xlt4x4
I would think so. You could also install a 3" body lift if you want. But they usually run 200 with everything needed, plus lots of install time. Go to a tire shop or something and see what they reccommend doing, and how much it will cost.
kain
1997 - 2003 F150
Apr 28, 2007 08:39 PM
nwtfox
1997 - 2003 F150
Dec 10, 2003 09:50 PM
98f250lightduty
Jun 9, 2003 12:10 AM
