Smoking dipstick!
Old May 3, 2004 | 10:20 AM
dougg's Avatar
dougg
Smoking dipstick!
I took a short trip (10 miles) to the lake pulling my boat (3000lb) with my 92 f150 302. When I got home I checked the oil. Oil level was fine, but the dip stick was smoking! Smoke was coming out of the dipstick hole as well.. Plus my oil gets black in color very quickly after oil changes.
Blow back? Something else?
I am looking for more torque for pulling and I am torn between upgrading the top of the 302 or replacing with a 351. If this is a sign of worn rings it makes my decision easier..
Thanks!
Doug
Old May 3, 2004 | 02:00 PM
ssn randy's Avatar
ssn randy
you guessed it.
Old May 3, 2004 | 04:44 PM
dougg's Avatar
dougg
I just had a thought,Could it be PCV?
I will have to check the valve tonight..
Thanks!
Doug
Old May 3, 2004 | 05:00 PM
Big Orn's Avatar
Big Orn
Yes, it could be. But pulling that weight with a 302 can get the oil quite hot causing the valve seals to weaken.
Old May 4, 2004 | 02:42 AM
Superdave's Avatar
Superdave
I think it sounds like blow by.
Worn rings, like you said.
Have you pulled the oil fill cap while the engine is running to see if the smoke is coming from it as well?
The oil turning black quickly after an oil change sounds like rings too. The blowby contaminates the oil.
Old May 4, 2004 | 08:46 AM
dougg's Avatar
dougg
I checked the PCV, and it is fine. I also get smoke out the back in the morning...
So my hunt for a 351 begins..
Thanks all..
Doug
1992 f350 4x4 7.3
Jun 17, 2015 05:51 PM
jeffg_208
Aug 30, 2014 09:15 AM
BigDoug
Aug 6, 2014 01:30 PM
BroncoRoadKill
Mar 27, 2005 10:02 PM
pinegreen
1983 - 2012 Ranger & B-Series
Nov 27, 2000 04:33 AM
