Sponsored by: Auxito
Rear Cabin Leak
Old May 3, 2004 | 01:20 AM
TrevHat's Avatar
TrevHat
Rear Cabin Leak
Howdy all!
I just inherited a 98 F-150 and have a slight problem. The rear cabin has a small leak that slowly allows rainwater onto the back seat (just enough to give the cabin that wonderful mildew aroma). I took the truck into a Ford dealership and they gave me an estimate of $200 to replace the seal. My question is: Is there some sort of caulking-type product availabe that I could use instead of what I think is too high a price for a water leak fix?
Thanks in advance...
Old May 3, 2004 | 10:16 AM
98 4.6 locked up's Avatar
98 4.6 locked up
You could buy the parts to do it from the dealer for about 50 bucks. It is the butyl seal and a new cover for around the outside of the window. If you look thru previous threads you should be able to find the directions.
Old May 22, 2004 | 12:29 AM
off road ford's Avatar
off road ford
if you have a slider window the frame is crack. mine was crack in three places
Old Jun 4, 2004 | 08:10 PM
CEKincaid's Avatar
CEKincaid
I have a 97 that had the same problem. Come to find out that the window frame was cracked.
Old Jun 5, 2004 | 07:58 AM
stantojl's Avatar
stantojl
Had the same problem my self. Cracked frame. There is a TSB from ford on this. Pulled the window frame, installed the gusset seal (from the TSB) and a new butyl seal and hasn't leaked since. There are quite a few threads on this.
Carguy212
Oct 13, 2014 05:45 AM
ColoradoGeorge
Oct 24, 2011 09:30 PM
jimmyburg
Air Intakes, Air Filters & Ram Air
Oct 16, 2008 11:54 PM
6686L
Jun 23, 2008 11:24 AM
gmoneyr.n.
Apr 24, 2006 06:59 AM
