I Hope i posted this in the Right Area I have a f150xlt 1997 ford pickup i started it up and the ABS Brake light came on the air bag light came on and would not go off and the Radio and ac fan would not come on But when i shut it down and restarted it everything was working ok, Does any one have any ideas what may have caused this?
You may have noticed that we don't allow e-mail address on the boards.
Because user's are asking questions on a Technical Forum, we would hope that user's would want to help us Keep the tech answers on the forum, instead of privately through e-mail.
Maybe your ignition lock cylinder is sticking partially between run and start. Take out your ignition lock cylinder and lube it up real good and that may help a lot. Sometimes we have to replace the chime switch on the lock cylnder because it hangs up the cylinder.
