Sponsored by: Auxito
rear end question
Old May 3, 2004 | 12:56 AM
The Phenom's Avatar
The Phenom
rear end question
is there anyway to change rear end gears and not have to buy a programmer to fix the speedometer? like if you are exchanging them from 2 trucks is there anything else you could swap to make the speedometer correct?
Old May 3, 2004 | 10:22 AM
superrangerman2002's Avatar
superrangerman2002
There is one other way, but that includes a trip down to the local Ford dealer, to reprogram the computer. This route may be cheaper and worth your time to call up a local dealer.
Unfortuntely there are not any magical parts that can be swapped. Vehicle speed is read of the abs ring in your differential, the ring has a bunch of teeth in it, and uses the sensor in the top of the pumpkin to create a signal that the PCM uses with the gear ratio number, that is programmed into to it, to generate a signal that is sent to your speedometer.
In effect the magical swap that is needed is to "swap out the gear number" that is in the PCM, and this is done with a tuner, or a trip to the Ford shop.
Old May 3, 2004 | 11:03 AM
JustinH's Avatar
JustinH
Any real tuner can take care of this in the eec, not just the dealer.
jaebird1
Jun 21, 2011 02:17 PM
Kenworth350
Mar 11, 2009 08:30 PM
phyrphighter
Sep 27, 2007 08:35 AM
Little Foot
Jan 4, 2007 09:38 AM
GreatNorthWoods
Jul 25, 2005 04:25 AM
