need some bigtime help
Old May 2, 2004 | 11:00 PM
mixed_up101's Avatar
mixed_up101
ok i just finnished fixing the fuel pump, the peice that conects to the "out take" end of pump, its hallow and it screws off, anyways no i cant get my bronco to to run ( 1988 ford bronco xlt 4x4, with a 351 V8 EFI HO ) it runs for a few seconds ( from 2-12 seconds ) and boggs out, almost like getting not enuff fuel or to much, or the sparkplugs stop, and if i press the peddle at all, please help me someone
Old May 3, 2004 | 11:30 PM
LxMan1's Avatar
LxMan1
Have you checked the fuel pressure? If you have good fuel pressure 32-39psi, then I might suspect the ignition module is bad.
Old May 3, 2004 | 11:36 PM
mixed_up101
ignition module
whats a ignition module??
sheriff923
1978 - 1996 Big Bronco
Mar 20, 2008 09:22 AM
dadrich67
15
Feb 20, 2008 07:03 PM
mightypuppetmaster
Bronco II
Oct 29, 2007 12:14 PM
Brewer51
Bronco II
Oct 13, 2006 03:36 PM
yosemite
May 9, 2003 10:31 PM
