Bronco II Ford Bronco II
Fuel Pump Problems
Old Oct 12, 2006 | 11:41 AM
Brewer51's Avatar
Brewer51
Cool Fuel Pump Problems
I have a 1987 Ford Bronco ll and it just died along the road. Had it moved home and have been working on it ever since. I replaced both fuel pumps, fuel filters and both relays ECC and FP. When I turn the Key on both relays activate but the fuel pump relay only stays activated about 10 seconds and it cuts out the fuel pumps never get voltage to run. Also have replaced the ignition switch. The inertia switch works as I get voltage to the fuel pump connector for about 10 seconds and it cuts out make the relay cut off power to the pump. Also the Computer has been replaced. Any Ideas??
Old Oct 12, 2006 | 01:24 PM
Eric C.'s Avatar
Eric C.
Does the fuel pump even start when you turn the key? After 10 seconds the relay deenergises till there's oil pressure. Try rigging a jumper from the hot to the power to the pump. I don't recal what normal pressure is right now. If you have proper fuel pressure then you need to start checking the ignition circuits. I had a problem with my F-350 like this when it got hot due to a bad pickup in the distributer.
Old Oct 12, 2006 | 01:53 PM
Brewer51's Avatar
Brewer51
I never get the fuel pump to kick on. The relay clicks off before that ever happens. I have no fuel pressure. I relieved the pressure when I changed the pumps and never got the pumps to kick back in. I am going to jump voltage to the relay tonight and see if the pumps run and if they do it will send me to the ign switch. Do you agree???
Old Oct 12, 2006 | 02:46 PM
87 XLT's Avatar
87 XLT
If you are saying that you do have voltage to the pumps the problem is on the ground side of the circuit.
Does the fuel gauge work??
The gauge AND the pumps are spliced to the same ground.
Old Oct 12, 2006 | 06:06 PM
matlock01's Avatar
matlock01
My 85 died on the road one day and I thought it was the fuel pump. turns out my problem was the TFI module. You might want to check that.
Old Oct 12, 2006 | 09:46 PM
BCTom's Avatar
BCTom
Ditto what Matlock states. My experience with fuel pump failure involves stumbling under part throttle and hesitation during acceleration. Check for fuel pressure at the schrader valve on the fuel rail. Without pulling codes I would suspect the TFI module. There are test procedures on the FAQ page. Good luck.
Old Oct 13, 2006 | 03:36 PM
rebocardo's Avatar
rebocardo
I would suspect the TFI first.
If you have replaced both pumps, you might have to bleed your system, though it should do it itself.
What you do have to do is turn the ignition to the ON state three to six times in a row to prime the system before trying to start.
Make sure the connector for the fuel pump (high pressure) in the rail is okay and take a voltage reading there.
dakota-boy
Electrical Systems/Wiring
Mar 14, 2016 09:29 AM
CRAZYC123
Aug 26, 2011 10:02 PM
Brewer51
New Member Introductions
Oct 11, 2006 05:21 PM
Traderjoe28
General Automotive Discussion
Jul 21, 2006 03:33 PM
slammindeuce
1983 - 2012 Ranger & B-Series
Dec 17, 2001 11:21 AM
