Holy smokes, only 7.5 MPG?!!
Hi all. I just picked up a '93 E350 cargo van real cheap. Immediately notice that it's running rich enough to smell. After running my first full tank through it I realized it's getting about half the mileage it should. Other symptoms include a slightly rough idle (sounds like it's loading up, then clearing itself) and it takes an abnormally long time to reach normal operating temperature. Other than the o2 sensors and a complete tune up, what else should be done? Thanks in advance.
The ECT (Engine Coolant Temparature) Sensor can really wreak havoc when it gets old. It'll tell the computer that the engine is cold, thereby staying in Warmup mode. Sortof like having a stuck choke.
ECT's cost around $15-30(20-30 for MotorCraft) depending where you get it, Good PM to replace every 100K IMHO
A lopey idle is charcteristic of some 5.8 EFI. Though not very radical.
-J-R-
-J-R-
Shouldn't be a problem to burn the tires with the lighter rear weight distribution in a regular length van.
To solve that, you'd need Traction Control, like my 88 has? 4.9L EFI + 5400 lb Curb Supervan.
I had a 92 F 250 with 5.8 E4OD, and it had just enough weight that it couldn't burn em'
But all it took was a helper to lift the rear, and Howwwwwwl!!!
I've had two 5.8's and both had the lope, the AT did it especially well.
I've read the TSB for the fix, and Ford tells the mechanic that if they can't solve the problem to tell the customer that the idle is characteristic of the 5.8's high overlap cam. With which it does have the highest lobe lift of the pushrod EFI engines.
-J-R-
-J-R-
