I have only found 2 choices in 285 17's, BFG's and Goodyears, not much out there, thats why I was comtimplating going to 265's, way more choices and those Coopers were real affordable!
I just put Michelin LTX MS 265 70r 17 on my 2004 XLT, 2WD. They look great, and are really well made-- they had stellar user reviews at Tirerack website. I was also considering Pirelli Scorpions, but on examing both at Discount tires went with the Michelins.
They are handling well, tracking is right on / no pulling. They also sit half an inch higher than my buddies Wranglers RTS same size.
I feel a slight loss pickup starting out (not at highway speeds) and a I feel little more work in handling (just a bit). I'm sure this is from the added weight/mass at the wheel. Also with the 265 I have plenty of clearance at the wheel wells.
If you go to 285s handling and power may be become a bit of an issue, and it may be tight in the well without a lift or daystar.
Gotta go with the 285 BFG's. i have put them on my last three trucks. they set the truck off. 265's will look just like every other truck out there.
I took delivery of my 04 and drove it to the tire store for 285 bfg's on factory 17's. raised white letter out, and no lift,no problem
