It's been sick lately. Put new TP sensor in (had to break off the old one. Was loctite'd in), new coil packs. Had a code for tp sensor, but not coil packs. :/
Cured most of my power loss though.
Got the wrong PCV valve at the parts store. Have to exchange it tomorrow. That should cure the spitting.
She's still got pretty low compression though. I'm a little worried about that. She still seems sluggish off the start, and ran comp test. 120 psi at 5 strokes on all cylinders, +/- 4 psi.
This is in addition to:
New timing belt and tensioner
new injectors
120 seems like it's starting to trail off a little there. How many miles do you have on her? And just out of curiosity, did you remove the throttle body to get at your TP sensor? On mine it looked like I could get at it with a stubby phillips screwdriver, but I haven't really tried digging around at it. I'm doing that today.
I had to remove the upper intake and file down the sides of the screws and replace them. They were loctite'd on. :/ Stripped my screwdriver pretty quickly. If you have a larger phillips, like a #3 or so, would be best.
Also had to remove the IAC to get to it.
Has about 210k, so not too shabby for it's age.
Reason: adding mileage info
I had a chance to review the code and it's all about the fuel system, you need to run the pinpoint test J. Let me know if you need a copy, I can email it to you
It was running terribly. Couldn't figure it out until my dad reminded me about the cat.
It was completely clogged. Pulled it, dug it out and did a test run. Actually broke rubber on concrete. Just made a few neighbors mad as all heck tho. >-)
Welding it back on in the morning.
Also found a short under the bed when I was replacing the fuel pump. I may not have absolutely needed to do it, but it was gummed up something fierce. The bottom around the strainer inlet was actually rusting! Don't have the money to drain my tank and put fresh gas in atm, but I will soon.
Also found about 3 pounds of dirt around my fuel/electrical connecters.
I did, however, break one of the exhaust bolts though. Going to see if I can borrow a set of easy-outs. Think C-clamps will hold until next weekend.
