89 Ranger 2.3L Clanking noise while accelerating...HELP!
(MIND YOU I KNOW NOTHING ABOUT CARS SO BEAR WITH ME)
I am a new owner of a 1989 Ranger. I was lucky enough to receive it from a friend for $100 and I am looking into putting some money into it to fix it up. I have been having problems the first day I got it. First, while accelerating the truck would sputter...Almost like misfiring...Now there is a LOUD clanking noise that sounds like it is coming from the front of the truck on the passenger side...It only happens when I accelerate past like 10 mph or so...Can anyone help!?
Ask your buddy about all the tune-up parts. How old, what brand, etc.
If the engine is chugging, then it could shake external things loose. Is the truck an auto trans? You might be able to make the noise occur by putting the truck in gear and HOLD THE BRAKES REAL HARD while you give it some gas. You should chalk the wheels or chain the truck to a tree if you have to to keep it from moving. If you can do this SAFELY, then you can have somebody looking/listening at the engine.
Hopefully you understand that this proceedure could be very dangerous if not performed properly.
I am not too sure of the noise you are hearing, that fan/shroud suggestion was good. Might want to check the exhaust/manifold/cat too (my 4 banger is on the passenger's side). As for the sputtering, could be a damaged distributor rotor. I have also seen cars spit and sputter with a cracked cap, or old/damaged plug wires. Also check that ignition coil on the fender well near the distributor (if your truck is equiped with that)
I appreciate both of your suggestions...The car is manual...We just replaced the rotor/cap yesterday and put a new positive battery cable on. The car is still making the clanking noise. He seems to think that it is the exhaust manifold.
G2IC_Wraith - I will check into all of your suggestions on the Ignition coil & damaged plugged wires...
Sounds like your exhaust is broken off the head bud. Take a look at passenger side of your engine on a dark day. Have a buddy shine a flashlight up the side of the engine from below. If you see light between the exhaust manifold and the head you've got a problem. Couldn't say how serious until you get into it.
Cheapest possible alternative would be to get a set of easyouts and drill the broken bolts then back them out. It's kind of a hit and miss thing tho.
Might have to replace the head. Daunting task, and not cheap.
But you never know, it's more likely that the exhaust pipe has broken somewhere between the manifold and the cat.
imasupernova - I hope this will help you, but I don't think it will be good news. I have broken, damaged/destroyed and replaced 7+ catylitic converters in 3 cars. In a few of this cases thay made alot of noise and also would not pass emissions. I have never seen the inside myself, but the sales rep said the way the cat is made is that there is a "brick" of material that exhaust gas passes over and through to remove the bad stuff. This "brick" came apart in at least 2 of my bad cats, and bounced around inside there like crazy. It made ALOT of noise, and it wouldn not pass essisions like that either.
If you have a leak in your exhaust manifold I don't think that would cause you to fail emissions. If anything, I would think that would help.
From all the symptoms you have listed, the cat sounds like the problem. And they do stink like crazy when they are bad. There are lots of possibilities but this is my best estimate. If there is something loose/broken, a rubber mallet and some well placed taps should reveal them.
An exhaust leak near (up or down stream) the O2 will draw air in and cause the O2 to read lean, then the ECU will try to correct by adding fuel to the mixture, causing a rich conidtion that the O2 doesn't know about.
Good point, forgot about that pesky O2 sensor. If it leaks in the right place this could happen. It would have to be pretty bad though to make the noise he is talking about.
