6 spd. clutch kill switch
I though all clutches had a not start switch on them.?
Are you wanting a kill switch for auto theft deterrent?
please explain your intended use.
gseeders
Prostang
Ok, here is what you do. at the clutch switch there is two wires cut one of them,run a wire from one end of the cut wire to the toggle switch, now run another wire from the other cut wire to the other side of toggle switch. your done!
It will not matter which wire you cut at the clutch switch.
only cut one of the wires.
I would cut the wire away for the clutch switch so its not apparent what your doing.
over and out
gseeders
I have clutch switches go bad and have never had a trouble code.
If you want proof, unplug the switch,If you get a service light to come on then it will,if not then it won't.
If you get a trouble code,in which I truly don't think you will,but if you do disconnect the battery for a few minutes. This will clear any codes stored in the computer.
Will this work on an automatic as well? My beloved truck sits on the street in front of my house because it will not fit in the garage.
I would like to add a toggle switch that will prevent the truck from being taken out of park.
Thanks for the information. :7
Steve
Something that would make this idea pointless is that you can shift out of park without pushing the brake pedal, by only turning the key part way but not too much were you get dash lights to come on. then put it in nuetral and start.
(I'm not tring to "P" anyone off here just getting this out)
(And go ahead and correct me if I'm wrong)
Now for the automatic application. yes it will work, the neutral safety switch is off the same principle.
over and out
gseeders
>jumper the starter with a screwdriver??
use to work just fine on older cars without lock steering wheels
I think that most car thefts just pop the ignition and use a screwdriver and go. The toggle switch is to disable the clutch switch which would prevent the vehicle from starting.
>>I would like to add a toggle switch that will prevent the truck >from being taken out of park.
The toggle switch is not to prevent the truck from being taken out of park but to disable the switch thus preventing the vehicle from starting.
Have you ever tried to start you vehicle in gear? Won't work because of this switch.
If the switch is disabled then it won't start. Doesn't matter what position the key is in or what position the gear shift lever is in.
your not "p" me off / corrections made!
you can have a $600.00 alarm system, doesn't always protect what you have!
The toggle switch method is very cheap, and very affective..
These methods are just this (DETERRENTS).
If it stops just one theft,then its worth it. hopefully most of us will never have to go through the experience.
over and out
gseeders
>Have you ever tried to start you vehicle in gear? Won't work because >of this switch.
Have you tried starting you vehicle in neutral? You can, I've done it. Others I know have done it.
And back to the manual transmisions. Has any one heard of poping the clutch? I'm sure most of us can do that.
I like the fuel pump cut off idea the best.
My 2001 power stroke with the R4100 auto tranny has a digital transmission range sensor. It will only start in park and neutral. If you disable this sensor, YOU WILL NOT BE ABLE TO START THE VEHICLE.
The starting circuit is wired through this sensor. Disable the sensor and you effectively disabled the starting circuit. Later model vehicles use a neutral safty switch, this is of the same principal as the (DTR) sensor.
Now you have us pushig a 7000# to 8000# plus truck! HAHA!!
These are not my ideas. I have just been around awhile and have seen a few things. I didn't start this post, someone ask and I responded. you can "would if and all of that" all day long but it still won't change the fact that these ideas will work,some better than other. These ideas are not full proof, and I don't think that everyone thinks that thay are. "There just deterrents"
If I was a professional car/truck theif I would have a wheel lift on the back of truck and within a minute I would be gone with the vehicle without starting anything.
got to go
over and out
gseeders
