front drum brake HELP!
Old May 1, 2004 | 11:21 AM
75f100's Avatar
75f100
need help, front d44 1/2 ton drums. i have no pedal feel in the truck and when i try to bleed them there is no pressure going to the front. both sides are the same, not just one or the other. is the center line to the axle bad? what else to look at. have new master cylnder also.
Old May 1, 2004 | 11:37 AM
75f100's Avatar
75f100
just more info, when i bleed the front the fluid comes out, but it just drizzles out, not like under pressure.
Old May 1, 2004 | 12:09 PM
hdgapeach's Avatar
hdgapeach
Did you bench bleed the master cylinder before you installed it in the truck?
Old May 1, 2004 | 02:31 PM
ranger429's Avatar
ranger429
It does not sound like it.
Old May 1, 2004 | 03:37 PM
75f100's Avatar
75f100
problem solved, the proportioning valve was stuck, blocking off the front brakes. thanks
51PanelMan
May 30, 2014 03:50 PM
MUJA1001
35
Dec 12, 2010 08:32 PM
dadstruck
58
May 6, 2008 08:56 PM
1ole4d
Jan 14, 2007 01:53 PM
n2gs
Jun 1, 2005 07:06 PM
