No Speedometer , No ABS, Overdrive is flashing!
Old Jun 16, 2002 | 10:40 AM
Jakeman68's Avatar
Jakeman68
Old Jun 29, 2002 | 04:35 PM
MisterFord's Avatar
MisterFord
2000 FORD Powerstroke
Speedometer not working, ABS and overdrive isn't either. I took out the sensor mounted on the rear differential cleaned it off with no results, I bought a new one for $11.84 and still I get nothing! What next? Fuses look good to. Do I need to reset the computer or what the #$@%?!!?
Can anyone PLease help??!!
Thanks,
Mister Ford
Old Jun 30, 2002 | 08:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is the overdrive light flashing? If so, there is a code stored. You need th code to diagnose what's wrong. Without the code all you can do is buy parts and install them, while hoping you find the problem before running out of money.
If you don't have access to a scan tool, AutoZone has been advertising that they will read the codes free.
Mark
Old Jun 30, 2002 | 09:14 AM
wolfmanagh's Avatar
wolfmanagh
I think I'd start first by checking with the plugs and wires on the transmission. After that I'd probably bring it in to a tranny shop cause its most likly the computer in the tranny has gon bad.
Old Jun 30, 2002 | 03:41 PM
Mark Kovalsky
>tranny has gon bad.
Not likely. The same computer runs both the engine and transmission, so if the computer had a problem the engine would be running bad, too.
There also isn't any connection on the transmission that can make the speedometer and ABS not work. This is not a transmission problem.
What does connect all three is the vehicle speed sensor. Since the sensor was already changed it's probably a problem in the wiring to that sensor.
I'd still start with pulling the codes. That will give a very good clue as to where to begin.
Mark
Old Jun 30, 2002 | 10:15 PM
MisterFord's Avatar
MisterFord
I had the parts store check for a code, and found nothing. But the overdrive doesn't blink until you start driving over 10 to 20 mph. Would that be a better time to try to read the codes? .....Probably not, but just a thought. ....Well, I guess I'm off to the Ford Dealer Tomarrow.
Thanks, you guys, for all the help.
I'll still be checking back for any new info.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
