6-Speed
Old Apr 30, 2004 | 01:22 PM
mwierowski's Avatar
mwierowski
6-Speed
This is my first 6-speed, should I be starting of in 2nd gear if not towing or empty load? I know the first gear is lower than the 5-speeds, but wasn't sure what was recommended.
-Mike
Old Apr 30, 2004 | 01:50 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You can start off in any gear you like.... I never use L except whith a trailer. Normally I start in 1 unless I'm rolling a little bit (like through a stoplight) or at least on level ground, then I'll use 2 (which is actually third gear of course).
The gear ratio's are actually pretty close between the ZF-5 and ZF-6, we just have an extra one splitting the middle gears.
Old Apr 30, 2004 | 01:51 PM
cgl's Avatar
cgl
I like to think of it as a true five speed with a granny low. The L (low) is really your first gear. So the 1 on the stick is really second gear, 2 is third, etc, etc. I almost always start out in 1 (which technically is second). If I have a load, on a hill, or if I'm tryin to save my clutch, I'll use L. I also found out that after time, the shift from L to 1 gets easier. Does that help you out at all?
__________________
2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
1990 F-150 Lariat 4x4 I-6 5spd RC SB
---Also in Family---
2003 F-250 XLT FX4 6.0PSD TSA SC SB
2001 F-150 XLT 4x4 5.4 AT SC SB
Old Apr 30, 2004 | 04:13 PM
wcmo sae's Avatar
wcmo sae
Whenever I drive one, I start out in second (1 on the ****) about 90% of the time. The only time I don't is when I'm stopped going up a steep hill and need that extra power to get up it. AS far as a "rolling stop", you might be able to get away with leaving it in third (2). Just my experiences. I test drove another one yesterday and fell in love with it, even more than the one I was ABOUT to buy. Hope this helps.
Old Apr 30, 2004 | 07:04 PM
mwierowski's Avatar
mwierowski
Yes this helps, thanks!!!
-Mike
v6lightning
13
Oct 21, 2012 05:26 AM
carlsson
Mar 23, 2010 10:27 PM
blueovalman
Modular V10 (6.8l)
Feb 21, 2008 08:22 PM
ghunt
Aug 13, 2007 01:06 PM
x12secondjourney
Modular V10 (6.8l)
Jun 12, 2004 07:23 PM
