Ring squeezer question
Old Apr 29, 2004 | 07:54 PM
lee's Avatar
lee
HELP!
I'm so darn mad right now I could bite a 10 penny nail in two. I just broke an oil ring while trying to install a piston in the block. I'm using the metal band with the square drive adjuster style of squeezer that I got at the local Shucks. I had it "squeezed" as tight as it would go but was obviously not tight enough. While tapping the piston in I broke the ring!!!!
Someone set me straight on what kind of ring squeezer I should buy.
Also are there any tricks to doing this that I don't know of?
Thanks,
Old Apr 29, 2004 | 11:10 PM
bassdude's Avatar
bassdude
those things bite! i just threw mine against the wall after i barely got the last piston in the hole. oh well can't expect much for 10 bucks.
Old Apr 29, 2004 | 11:41 PM
mark a.'s Avatar
mark a.
You just have to faness it right. First you put it over the piston, tighten it up then put it in the bore and tap the compressor band lightly at the top, so it is flat with the deck you don't want it wound like a spring, then tap the piston untill its close to the rings going in, then tap the end of the compressor again and retighten, and then tap it in. You just have to take your time with them.
Old Apr 29, 2004 | 11:48 PM
bassdude's Avatar
bassdude
yea i didn't mention that it was workable. i VERY gently tapped the compressor so the edge just went into the beveled edge at the top of the cylinder. then tapped the piston down in and it worked OK. the thing that ticked me of was the ratcheting mechanism stripped after the first one so i had to hold the thing tight with one hand and do everything else with the other.
Old Apr 29, 2004 | 11:56 PM
mark a.'s Avatar
mark a.
I've had the little pins at the end of the bands come out and reek havoc. Then they wont wind up right.
Old Apr 29, 2004 | 11:58 PM
DW2455's Avatar
DW2455
Use plenty of oil and take a rat tail file and chamfer the tops of the cylinders to make shure there are no burs or edges that will snag a ring as it goes in. DW
Old Apr 30, 2004 | 12:52 AM
Racerguy's Avatar
Racerguy
After using a tapered ring compressor like the one at http://www.powerhouseproducts.com/st...de=PISTON+RING you'll wonder how you ever did it without one.
Old Apr 30, 2004 | 05:29 PM
ga302p's Avatar
ga302p
the tapered one piece installation tools are the best. Can get expensive if you use many different sized pistions.
Tideman
Oct 16, 2016 08:50 PM
lincolnrig
15
Mar 24, 2016 12:30 PM
Macrobb
Oct 12, 2014 02:08 PM
bohdi36
Oct 21, 2004 11:10 AM
KJKozak2
Jun 18, 2003 02:04 PM
