Fuel Pump Questions?
Old Apr 29, 2004 | 07:00 PM
danlee's Avatar
danlee
My electric fuel pump has been giving me flooding problems, so I decided I would hook up a mechanical fuel pump to see if the problems clear up.
I purchased a cheap replacement fuel pump for a 1979 F150 2wd for a 6.6L motor. My 400 has not had a mechanical pump since I have owned it.
The directions with the new pump don't specify how the pump is to be installed. I think that the fuel line connections should be 'down' near the oil pan.
The two connections are not marked either. One connection has a female fitting for connecting a hard line, the other is a 'hose' type connection.
Is the hard line the input from the fuel tank?
Is the hose connection the outlet to the carb?
Old Apr 29, 2004 | 08:27 PM
freak98's Avatar
freak98
I'm pretty sure the hose connection is to the tank supply.The female is to the carb.From the factory Ford used a 5/16" hard line up to the distributor then they used 5/16" hose the rest of the way.What up with your electric pump?Do you have it regulated?I doubt that stock pump will supply enough fuel to your motor,it wouldn't on mine.
Old Apr 29, 2004 | 08:40 PM
danlee's Avatar
danlee
It is a Carter Electric pump. I have been using it for several years. It is regulated at 5 psi, and I have a fuel pressure gauge in front of the carb. Recently I noticed the motor was missing and running rich. The gauge was reading 6+ psi and pulsing. The pressure went back to 5 psi and the motor ran fine again for a while. Now the pressure is 6+ all the time.
I called Carter and they said that the regulator valve was probably sticking. Those pumps are not rebuildable either.
I will replace the electric pump as soon as I know for sure that it is the cause of the problem. I'll remove the mechanical pump and keep it and the plumbing handy for future problems.
Old Apr 29, 2004 | 08:46 PM
freak98's Avatar
freak98
I have a Holley blue pump on mine with their regulator.I have a fuel pressure gauge by the carb.
Another one in the cab.
They both run at 5.5 psi.
Old Apr 29, 2004 | 09:14 PM
freak98's Avatar
freak98
I have the pump in the back by the sump.
LowBudgetF250
Jan 31, 2017 01:49 PM
abstractbart
Aug 16, 2016 04:17 PM
cubanice27
Nov 5, 2015 06:39 AM
njjr
Oct 9, 2015 02:54 PM
jtarkington
Oct 26, 2007 04:35 PM
