My 1989 F150 is not getting fuel. I changed the middle tank and the sending unit and pump.
Should it be pumping fuel by itself. I disconnected the fuel line where it connects to the frame mounted pump and turned the key but no fuel comes out of the hose. I pulled the frame mounted hose for testing and it is working. I suspect the relay. Pulled it but the connections were corroded. I can clean them but how am I going to clean the ones in the connector harness?
