electrical connectors
Old Apr 29, 2004 | 10:20 AM
learpilot's Avatar
learpilot
Can anyone reccomend a source for good quality connectors for use in rewiring a 56 F-100. I am looking for permanant and the type that can be uncoupled as needed. Thanks for any help.
Old Apr 29, 2004 | 11:02 AM
76supercab2's Avatar
76supercab2
You might want to check http://www.digikey.com
Look for a manufacturer called Molex. They make connection hardware. If it is in cab / out of the weather, regular connections would work. Under hood I would look for weather tight connections (I don't know if Molex makes weather tight but check). You would need to get male pins, female pins, male plugs, female plugs (the plastic parts the pins go in), a pin crimper and a pin pusher (for removing pins from the plastic connectors).
Old Apr 29, 2004 | 11:26 AM
nick88f150's Avatar
nick88f150
www.mcmaster.com, ull hafta do a bit of searching, but i found em, wont le me post the exact link tho.
Old May 1, 2004 | 12:12 PM
94F150-408's Avatar
94F150-408
Locally for a small selection of Molex connectors you can go to Radio Shack, they do have some in stock. If your doing a large job, which it sounds as though you are, you will probably find better pricing on the web.
onestopbusiness
2004 - 2008 F150
Oct 16, 2016 10:55 AM
holdendaniels
Mar 20, 2016 06:04 PM
dwt2011
Jun 29, 2015 01:33 PM
Nickiboy
Aug 11, 2008 08:12 PM
bf5113
Jun 6, 2006 07:47 PM
