radiator fan
Old May 1, 2004 | 09:24 PM
AK429's Avatar
AK429
Major problems - need help
Hey FTE fellow users,
first problem: i have a really crappy single honda civic fan hooked up to the radiator right now, on one side of it. i plug the wire into the battery every time i go somewhere LOL. do you know of the correct amperage switch? i want to go with dual fan kit, or maybe have the fans come on with the ignition, but don't know the wiring diagram for it, and it looks as if it may be totally non original.
second problem: the really small wire from the coil to the distributor is twisted together and bare and hanging in the air very dirty. The cap is new, but im pretty sure the plugs and wires are old. the rotor looks original, but i really dont want to have to throw down for an expensive new one if not necessary. The connection for the power to the starter from the voltage distibutor (which is a 0ga wire) is a little bare where it meets the dist, can that affect anything? I am wondering if it is most likely these problems that are causing my starting problems, or if it is the fact that the starter heat shield is a coffeecan, and i need to get a hardcore heat shield ( does anyone know of a hardcore heat shield, like that fiberglass material they use for plug wires?) The battery terminals are a little dirty but are tightened tight as can be
STARTING PROBLEMS: GAve it some cool-mediumhot driving around for a while then just kinda lit hte tires for like 10 seconds in my friends road. So i parked, and 2 mins later tried to start it, it was having some problems and wouldn't start, I thought maybe it was hot,but it was just clicking , so i tightened down the battery positive cable and that did the trick, pulled down to go thru drivethru to get food, kept stalling if i didnt give it gas, then totally conked out for 15 mins until i used starting fluid and it would fire over for a second then die eventually i got it started and gave it a lot of revs for 30 seconds then drove of without letting off the gas, and when i got to the intersection and had the revs as high as my manual drums would permit (400rpm's over normal) it stalled, and started up and i gave it gas and it went. going 30 down a road at semi low RPMs it died. towed home. ****ed. Please help with any suggestions i would appreciate it.
Old May 1, 2004 | 09:41 PM
Franklin2's Avatar
Franklin2
Here's a diagram. I know it's for foglamps, but it will work fine for electric fans. Substitute the fan motors for the foglamps in the diagram.
Substitute any hot in run wire in the fuse box for the "lowbeam" wire in the diagram. This will give you 12 volts to the dash switch anytime the keyswitch is turned. Hook it to anything you want, since the power feeding the switch is only driving the coil in the relay, which draws very little current. All of the high current will be coming directly through the 10 guage wiring from the battery/30 amp fuse(or circuit breaker).
Old May 1, 2004 | 09:54 PM
AK429's Avatar
AK429
edited massively, thanks so far
5Rangers
Jul 25, 2011 09:42 PM
DemonRace6
19
Dec 16, 2010 11:37 AM
kontoboy
Sep 12, 2010 10:58 PM
Damonkr
Mar 25, 2010 09:04 AM
DRRXR
31
Mar 23, 2010 10:16 PM
