14 or 16 gauge
Old Apr 29, 2004 | 04:23 AM
airwick51's Avatar
airwick51
14 or 16 gauge
Im building a bed and wonder how many millimeters 14 gauge and 16 gauge are? I see that normally you use 16 gauge but heavy duty beds are made from 14 gauge.(which I guess is thicker) I was thinking of using 2 mm thick plates.Would that be thick enough?
Old Apr 29, 2004 | 07:09 AM
4tl8ford's Avatar
4tl8ford
http://www.engineersedge.com/gauge.htm
Old Apr 29, 2004 | 01:33 PM
airwick51's Avatar
airwick51
Thanks-That means if I understood the chart correctly that 16 gauge is around 1,5 mm and 14 gauge is around 2 mm. Right?( if one inch is 25,4 mm)
Old Apr 29, 2004 | 11:47 PM
53Merc's Avatar
53Merc
Question
Airwick,
I'm not sure of the metric equivalents but I believe the original boxes were 18 gauge, however I did mine in 16 gauge an dI'm glad I did.
What gauge sheet metal have the rest of you used on your bedsides?
GW
jrwendell
6.7L Power Stroke Diesel
Jun 14, 2011 07:01 AM
moxy123
Paint & Bodywork
Dec 31, 2007 03:26 PM
swanee
May 16, 2006 12:34 AM
aeroadc11
Jan 9, 2006 07:15 PM
jjohn85
2004 - 2008 F150
Nov 29, 2004 07:31 AM
