electrical connectors
Old Apr 29, 2004 | 10:35 AM
learpilot's Avatar
learpilot
Can anyone reccomend a source for connectors to use in rewiring my 56? Looking for permanent as well as the type that can be disconnected as needed. Thanks in advance
Old Apr 29, 2004 | 12:49 PM
LEckart's Avatar
LEckart
Most of the aftermarket wiring kits come with crimp type connectors that can be purchased at any good hardware store or Lowes, Home Depot, etc. If you don't have a good crimping tool be sure to purchase a good one, like Klein or such. The connectors come in a variety of sizes and configurations for permanent and disconnect situations. You will probably need the blue connectors for most of your wiring. You may also want to solder the important ones like at the battery or starter and then use the shrink cover over them. Good luck.
Old Apr 29, 2004 | 01:00 PM
51dueller's Avatar
51dueller
You have to be careful when soldering because you can make the joint brittle. All the vehicle companys only use crimp connections.
Old Apr 30, 2004 | 02:13 AM
angus's Avatar
angus
And don't ever solder wires before crimping them, or clamping them under screws. It looks neat, but the solder flows under pressure, and the connection will loosen in time.
I second the vote for the Klein crimp tool, specifically the 1005 or 1006 type.
holdendaniels
Mar 20, 2016 06:04 PM
jax2002f150
1997 - 2003 F150
Dec 26, 2012 11:24 PM
Nickiboy
Aug 11, 2008 08:12 PM
bf5113
Jun 6, 2006 07:47 PM
jeepin
Jul 8, 2003 09:07 PM
