EFI to Carb
Old Apr 28, 2004 | 08:39 PM
jwtimme's Avatar
jwtimme
EFI to Carb
Here is the deal, I have an 85 bronco that I just put a motor in and I took it out of an 86 bronco for a friend (he told me the 85 was EFI). Any way the 85 is not. I feel that wiring the bronco to EFI might be over my head, or take me a long time. So what would I need to convert to a carb. I know intake and carb, will I need to change the distributor, or can I use the stock. The stock has about 8 wires coming out of it. Which ones should I use. I will need to run an electric fuel pump. But I have the intake, an older street dominator intake from holly, will it fit this 86 motor. Should I try to make the EFI work before I convert. If so I need some pointers in getting started. I have been told only about 7 or 8 wires are needed to make the motor run but I have no clue which ones. And I have been told it is almost impossable to do. All info on this subject will be helpful.
Old Apr 28, 2004 | 10:30 PM
LxMan1's Avatar
LxMan1
The Holley intake and carb will bolt right up to the 85 or 86. Just use the 85 distributor and if you want to run a mechanical fuel pump, put the 85 timing cover (along with the fuel pump eccentric from the 85 motor on to the 86 motor.
Old May 3, 2004 | 12:29 AM
Ford_Six's Avatar
Ford_Six
IIRC, evrything after 82 had feedback carbs and TFI ignition. I would recommend an older (around 78) DSII system, or a Perfomance Distributors unit.
Old May 3, 2004 | 11:32 PM
LxMan1's Avatar
LxMan1
If you have both complete engines, just swap the parts listed in my previous post and you should be fine, since both vehicles use the TFI.
