Knocking M
Old Apr 27, 2004 | 09:37 PM
olewilly's Avatar
olewilly
Knocking M
Hello!
I have a 79 Ranchero with a 351 M with about 87 K on it the motor has a knock that is definately in the bottom end, however it has very good oil pressure and when the RPM's are brought up above about 1,000 the knock goes away.
I don't know much about these engine's but I am thinking thrust knock, any help will be appreciated.
Ole'*****
Old Apr 28, 2004 | 12:37 AM
mark a.'s Avatar
mark a.
Sound like a main bearing.
Old Apr 28, 2004 | 01:04 AM
Snoozinglion's Avatar
Snoozinglion
I had a 351c in a /71 Cougar that developed a knock in the bottom end...
Turned out to be a connecting rod bearing....
Old Apr 28, 2004 | 09:50 AM
beartracks's Avatar
beartracks
Mains should knock under load. Rods under float conditions. Maybe the timing chain?
