Banks 4" exhaust best upgrade from stock?
I'd be shocked if the 03 Ford stock pipes on mine were stainless ?!?!?!!?
They looked like aluminized to me and,
like you say, SMALL compared to the aftermarket...
and don't even compare the downpipes -
it was like a crushed straw compared to the alaskan pipeline !
I did do the muffler delete for about six months and getting past the LOUD cabin from it...
once I put the turbo back on it I realized how restrictive the stock pipes WERE !!!
Originally Posted by hilbilly
I currently have a DPPI exhaust on an '03. The cat is in place. I can't hang with the jet-engine screech anymore!!! I ordered the Banks turbo-back yesterday. I kinda like my truck to sound like a truck, not an airplane. But to each his own, thats what makes the world go around.
hilbilly
hilbilly
I'm getting the Warpspeed Downpipe for my truck, and having and exhaust shop do a straight pipe back off of that. My question is, my exhaust shop has done one of these before and it took him almost 2 solid hours to get the stock DP off. Is there an easy way to take it off? Something that will save us 2 hours worth of heartache?
jdad You are correct. I forgot to add that stainless is better for areas that use salt in the winter. the point I was trying to make is that 4" is 4" doesnt mattter weather its aluminuim or stainless it will all flow about the same. For 2003 models banks does have the resonater on it to quiet the jet sound. I'm not sure about 2003, but 2004 does have 409 stainless pipe in 3.5 diameter. I removed the muffler and installed a straight pipe that I made out of some old exaust. I have collected a few from doing installs on other peoples trucks. I made it so that it just unbolts, so I can re-install the muffler for warrantee work. The point I was trying to make with HOG is that it has stainless steel hangers, is highly polished. which means less nooks and crannies for corrosion to collect, not to mention its priced $100's less than the banks. I'm trying to give as much info on the systems I've installed, so others can make an educated decision when buying. hope this helps Jerry.
#29
#30
the_auto_tech
03-25-2013 09:18 PM
crescentwrencher
49
05-03-2008 09:08 AM
