replacing the clutch
Old Apr 27, 2004 | 02:15 PM
revelstoke's Avatar
revelstoke
Hi There,
I have a 1994 F250 5 SPEED 5.8 LITRE and it doesn't shift as smooth as it did, I have also noticed a very slight vibration under load (ie.camper and load of dirt,gravel.) as I Begin to accelerate and then it goes away. I suspect that the clutch needs adjusting or it needs to be replaced. If the clutch needs to be replaced can it be done at home ? if so, will I need any special tools ? Does anybody have some experience thay can share ?
Thanks,
Revelstoke
Old Apr 27, 2004 | 10:10 PM
Natas Olbaid's Avatar
Natas Olbaid
which 5 speed do you have? also is it 4wd?
most likely this is something that can be done at home in a weekend, but it involves dropping the tranny, so it depends on how much work you are willing to put into it.
Old Apr 27, 2004 | 10:13 PM
hreed's Avatar
hreed
Before you pull the clutch, check the u-joints, transmisssion fluid level, hangar bearing, rear end fluid level, etc. Maybe some grease will solve the problem. Also check the clutch cylinder fluid level. I'm not sure on your truck but I suspect it also has a slave cylinder. Bleeding the system might help. Don't do major surgery until you eliminate the most likely problems first. One other thing, if you have a slip-yoke on your drive line, that can cause the problems you describe. And you will need some special tools to change the clutch. But not many. Make sure that is the problem first before taking everything apart. Keep us posted.
Old Apr 28, 2004 | 10:31 AM
revelstoke's Avatar
revelstoke
replacing clutch
Thanks, for the reply guys. I forgot to mention that the truck is 4WD. I will check out all the things mentioned this weekend and see where it leeds me.
Thanks,
Revelstoke
abowman
Mar 8, 2017 12:12 PM
53fordman1
Jul 28, 2016 12:01 AM
53fordman1
Jul 26, 2016 12:18 AM
qquake2k
Jan 12, 2015 05:30 PM
phillyshriv
Nov 3, 2014 08:48 PM
