What is this?
Old Apr 27, 2004 | 07:10 AM
nothingbutford's Avatar
nothingbutford
What is this?
And did I mess something up? This is about six inches down from the A/C Compressor connection on my truck.
Old Apr 27, 2004 | 07:14 AM
nothingbutford
For some reason the picture didn't show up...It's in my gallery.
Old Apr 27, 2004 | 09:19 AM
Franklin2's Avatar
Franklin2
What happened? Is this a picture of the wiring harness? I can't make it out too well, but one of those round things may be a diode that connects across the ac compressor clutch.
Old Apr 27, 2004 | 11:33 AM
nothingbutford
Yes, it's the wiring harness going to the AC compressor. I was tracing the wires back looking for bare spots and took that apart too. The bad part is I broke the leads on the diode or whatever it is (DUMB!) I guess I messed something up huh? I was mainly wondering why that is there and what it does. Just to understand it a little better. I'm taking a trip to the junkyard soon to try and find another wiring harness section.
Old Apr 27, 2004 | 08:20 PM
Franklin2's Avatar
Franklin2
The ac clutch is a coil, that when it gets current, magnetizes and engages the compressor. All coils are somewhat like capacitors. When they are energized, they develop a magnetic field around them. You can think of this field as stored energy like would be in a large capacitor.
When the voltage is taken off the coil, the field around the coil collapses, and all this stored energy runs backwards up through the circuit that feeds the coil. This backwards "spike" can damage the circuit that feeds the coil. So the diode is placed across the coil wires, to take out this spike of voltage.
The voltage feeding the coil has a + and a - polarity. The diode is like a electronic check valve, it will only let voltage flow one direction. And it just so happens the backward spike has reverse polarity. So the diode is placed backwards to the flow of normal current, but when the spike comes back through in reverse, the diode looks like a short, and kills the spike.
Old Apr 27, 2004 | 08:34 PM
nothingbutford
Thanks, That's cool. I understand about energized coils producing magnetic fields and charging & discharging capacitors. I had alot of that in Physics. They never taught me about diodes though. So I guess I better be finding a replacement harness or take mine to a computer shop and see if they will patch it for me. I wish I had known this BEFORE I messed with it. Thanks again.
05BlackTuscany
2004 - 2008 F150
Feb 9, 2015 10:41 AM
D Sokol
May 28, 2014 12:00 PM
cscott952
Mar 11, 2014 10:24 PM
Terpfords
User Gallery & Picture Display
Mar 3, 2012 07:30 AM
emtabmm
Jan 8, 2004 02:17 PM
