Fuel Additives
Old Apr 26, 2004 | 11:19 PM
Phydeaux88's Avatar
Phydeaux88
Question Fuel Additives
My recently pruchased 96 PSD has just over 110K on it. I do not know if it has ever had fuel additives/cleaners used. If I start to use them are there any precautions I should take
Old Apr 26, 2004 | 11:24 PM
Fire Rooster's Avatar
Fire Rooster
Yeah do not spill it on you it stinks really bad. No but read the full additives thread up there in the top three sticky threads. Diesel kleen seems to be the favorite. I like it too!
Fire Rooster
johnsdiesel's Avatar
johnsdiesel
Make sure you only use fuel additives that contain NO alcohol. This will negate the effect of the fuel/water seperator. I personally like Standyne and have also used Diesel Kleen. I run Standyne Performance Formula at every fill up and Lubricity Formula when I change the fuel filter. I fill the fuel bowl with the additive when I'm changing the filter. The Performance Formula contains a cetane booster, but the Lubricity Formula is desinged to be a cleaner and lubricant. Running additives regularly helps to keep the fuel system clean.
Old Apr 26, 2004 | 11:39 PM
Phydeaux88's Avatar
Phydeaux88
Thanks !! I was mostly concerned that adding an additive, if one had never been used, might cause large amounts of gunk to contaminate the system and take out my fuel pump or other component.
Old Apr 27, 2004 | 12:01 AM
diesel-lady's Avatar
diesel-lady
That would be an unhappy event. I've been using Diesel-Kleen. I don't know what the previous owner did, but since I started using it the truck runs a little smoother, and no more black smoke at startup. So the system was obviously a little bit gunky.
One thing about hanging out in this forum, a person could get real paranoid, and see nothing but perils everywhere.
Bobmurp1
6.7L Power Stroke Diesel
35
Mar 23, 2012 04:26 PM
villestrip
Dec 16, 2009 12:10 AM
g tinsley
May 14, 2006 08:03 PM
TDELONG83
Jul 26, 2004 09:00 AM
TBag7295
Feb 12, 2004 09:56 PM
