fuel additives
Old May 11, 2006 | 01:55 PM
g tinsley's Avatar
g tinsley
fuel additives
I was wondering which fuel additive is best for the 6 liter.I have been using power service but the local napa parts store reccomends lucus.I was wondering if any one has used lucus.
Old May 11, 2006 | 03:49 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Powerservice & Stanadyne are the two most popluar and engineered in my opinion. I am sure nothing wrong with Lucas, but does it have cetane improver... or just cleaners and lubricatnts? The other two brands have all that you, or your truck, will ever need.
Old May 11, 2006 | 07:14 PM
Maxium4x4's Avatar
Maxium4x4
Powerservice here also.
Old May 11, 2006 | 07:28 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Power Service here. Been very satisfied with the results and will continue using until I read/hear compelling reasons to switch.
Old May 11, 2006 | 11:16 PM
kw5413's Avatar
kw5413
Here is a good read on fuel ads...
https://www.ford-trucks.com/forums/s...d.php?t=409912
Old May 12, 2006 | 06:52 AM
35w's Avatar
35w
I have used both Powerservice & Stanadyne, right now using the Stanadyne mixed with Ford's Cetane Booster. This is the first tank with it mixed, will see how it works out.
35w
Old May 12, 2006 | 07:20 AM
gp42gpw's Avatar
gp42gpw
Thumbs up
Power Service here.
Grey in summer
White in winter
I have been using it since the first tank.
It's easy to find in my area.
Glen
Old May 12, 2006 | 07:30 AM
saftman's Avatar
saftman
Power service grey botle. Used to use Stanadyne but got tired of having to order it. A local fuel injection shop has it but it is in 16oz. bottles and is kind of pricey. I am going to try Shaeffers stuff next week.
Old May 12, 2006 | 08:48 AM
j_lauer's Avatar
j_lauer
35w,
Are you useing both of them at the recommended amounts or offsetting them? Have you noticed any differences in starting/takeoff/noise?
I was thinking about going to the Ford stuff but they only offer the Boost or the anti-gel. Currently running the White. they had it on sale at Wallyworld, but want to shift over the the Grey bottle.
Thanks
Jerm
Old May 12, 2006 | 09:16 AM
JRM6868's Avatar
JRM6868
I just started using powerservice, this is my second tank with it and I noticed my starts are easier and the motor is a little quieter.So far I like the results.Joe
Old May 12, 2006 | 09:35 AM
35w's Avatar
35w
j_lauer, I am using both at mfg recommendations. Seems the engine runs a little better
and the noise level seems lower. The starting seems about the same. Only have a 150
miles on this first tank so may be a little early.
35w
Old May 12, 2006 | 09:37 AM
bf250's Avatar
bf250
power service here, never heard of lucus, but then again, i never go to napa either.
Old May 12, 2006 | 09:44 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
I use the Stanadyne Performance Formula to make up for the lack of quality #2 available on the West Coast, my truck runs smooth at idle, never had an injector issue, lights right up cold or hot (30-105 degrees), very little smoke even with tuning galore, and runs hard. I very recently had the cab off my truck for headgaskets, and while it was apart started poking around for the satisfaction of my curiosity. The EGR valve was black from exhaust, but had zero carbon build up. When the heads came off, the intake, tops of pistons and valve stems were perfect, zero carbon. I realize this a very non-scientific observation, but have seen many trucks apart for headgaskets in the 14-75k range that looked like a coal factory had left its mark inside the engine.
Tim
Old May 12, 2006 | 02:22 PM
Beachbumcook
Got Diesel?
Check out an old thread I started about DFA's and even went so far as to call a few of them.
It's a good thread and I hope useful info that I posted... hope this helps (some)?
https://www.ford-trucks.com/forums/s...d.php?t=446262
Jeff
Old May 13, 2006 | 08:43 PM
kaipo's Avatar
kaipo
Power Service here and it rocks!
Aloha,
Kaipo
