Another noisy v10
happen at the top of each shift.(auto) It also dosnt happen till it warms
up .From all the threads I`v read in the last few weeks, (new guy), it
sounds like most of the tappin ,knockin, tickin is going on at start up only.
Any thoughts as to why it dosnt do it till it warms up.
thanks for any input (p.s.) great site
Like Lighthouse said, reset the computer first. Disconnect the battery
overnight, and then take it out on the highway, cruise at 70+ for a 5-10
minutes, pull over, coasting all the way without hitting the brakes, then
pull out slowly, speed back up to 70+, and then pull over again.
Then, MASH IT TO THE FLOOR, and go back up to 70+.
This will make the computer relearn everything and go into closed-loop ...
One thing, if it pings again soon after resetting the computer, you
probably have a bad knock sensor.
Funny story: I had a dirty MAF in my '96 4.6L T-bird, overoiled K&N.
Cleaned it, and according to the TSB about the fault code I got (lean bank
1/2), Ford says to get the computer to learn the MAF, I had to get onto
the highway, and in 3rd gear, keep my foot to the floor for at least 30
seconds (or a minute, or something like that).
Only problem was with my Superchip and a 3.73 rear, I was doing over
120MPH before the 30 seconds were up... and they said to repeat it a few
times! Mustang GT thought I was playing with him, and started to get
****ed off because he was losing ground around that 120 mark... funny...
t-bird was more aerodynamic than his 'stang...
As far as running super in it , Im sure its worth a try. But I dont think
its a ping. sounds more like a lifter tap to me . thanx for the help
If you hear a "tick" it could be your injector(s). This is not to say that there is anything wrong with them, but that could be the noise. Injectors click - that's their nature.
Otherwise it could be "piston slap" which could be a bad thing, or not, depending on the severity.
See this thread also (if you haven’t already). It’s a newer thread:
https://www.ford-trucks.com/forums/s...d.php?t=233386
