Modular V10 (6.8l)
Knocking for a second at startup
Old Apr 24, 2004 | 12:43 AM
cclgeo's Avatar
cclgeo
I have a 2004 V10 F350, and if I have not started it for awhile like a week or so, I hear a quick knocking sound right when it starts up. You know when you start the engine it quickly rpm's while it warms up. Right when the engine fires over, I hear that quick knocking sound. It only happens in the morning or after it has sat for a while. could it be because the oil is all down in the pan, or maybe because I should start it more than I do. Just wondering if anybody else has this happening, and it is just a V10 thing. The truck is new, and only has 5,000 miles on it. Let me know what you guys think. Maybe I'm just tripping out.
Old Apr 25, 2004 | 11:03 AM
trakman's Avatar
trakman
If I were you, I'd be heading for the dealership, Pronto!!!!!!
Old Apr 25, 2004 | 01:40 PM
Lost Hog's Avatar
Lost Hog
Question
Sounds like a little piston slappin goin on, I agree with tracman take her in asap and have em look at it, You may want to get an oil analysis done before you drain that oil out. BTW my LS-1 has done the same thing since 2000 miles, hasent caused any problems but I wonder whats going on in the bore wall.
Old Apr 25, 2004 | 06:28 PM
boxcar1974's Avatar
boxcar1974
A million post on this....Do a search for piston slap.......almost all V10's have it. Have the dealer document it and dont worry about it.....because there is no cure or fix for it.
Old Apr 25, 2004 | 08:28 PM
HeavyAssault's Avatar
HeavyAssault
I have the same thing. Generally found during extreme cold or long weeks of non-driving. I always considered the cause to be little/no oil due to the long sit.
Old Apr 28, 2004 | 09:05 AM
Sport45's Avatar
Sport45
I think HeavyAssult is right. Try installing a new motorcraft oil filter (an 820S, I believe). I think the anti-drainback valve in yours is allowing the oil to run back into the engine when you shut down. You're hearing valvetrain noises as the system pumps up. I tried a Fram filter once (only once!) with the same result.
Old Apr 28, 2004 | 09:23 AM
Baja Daze's Avatar
Baja Daze
All V-10's do that. It's quite common and most dealers won't spend even a minute on it anymore. Mine won't.
I posted the same thing a little while ago and the consensus was not to worry about it.
Old Apr 28, 2004 | 10:37 AM
Big Orn's Avatar
Big Orn
Also, this could be a Triton thing. My dad's and son's 5.4 both do it.
And, they are just alike (my dad and son) HARD on an engine! My dad's engine has 147K no probs - my son's 88K no probs.
BTW - I have the V10 "piston slap" and no problems to date: '99 SD F350 DRW with almost 90K miles.
Hmm - thought they would have at least toned it down some by now?
Old Apr 28, 2004 | 09:37 PM
lowet's Avatar
lowet
I had a 2001 with the v10, and now a 2003 v10 and when I ran a Fram filter and RP oil ( 10-40 I think) I had the same noise, I changed to the ford filter and 5-30 mob1 and it is gone ! I used redline or RP in my Mopar cars and fram filters, but not in my V10s or my 4.6 mustang.
RedDevil460
53
Mar 29, 2014 08:16 PM
blue924.9
Jan 28, 2014 09:11 PM
Trombogon
May 4, 2013 07:46 PM
tgen17
Modular V10 (6.8l)
Apr 27, 2011 06:49 PM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
