Mad Max
Old Apr 30, 2004 | 04:03 PM
spikedog's Avatar
spikedog
I suppose a rotary lobe blower could be spun by the air itself, since the engine would function as a vacuum pump. But it is still spinning...do you notice if the pulley is still turning on a dragster after the blower belt has flew off? On Road Warrior, the pulley is initially stationary. The case-to-lobe clearances on a rotary lobe blower are by design very tight - I just don't see any air getting past it if it ain't turning.
Old Apr 30, 2004 | 05:36 PM
ga302p's Avatar
ga302p
Originally Posted by spikedog
When your A/C isn't running, it doesn't block the air intake like a rotary lobe compressor. I suppose intake air might make it through a centrifugal supercharger even if it isn't turning, but no way will air make it past the lobes on Mad Max's Weiand supercharger in "Road Warrior."
That is exactly right, and even if it could get air, I would love to see the how those deep dished pistons you have to use on that S.C. would run with no boost.
Old Apr 30, 2004 | 05:42 PM
ga302p's Avatar
ga302p
Originally Posted by stevef100s
Not correct, Spikedog. Haven't you been watching drag races before when they pop a blower belt at the starting line? The engine still runs, and pretty fast too. Just not fast enough to win the race.
When they pop a blower belt, the engine instantly turns into a big brake. The inertia of the car is turning the engine, which in turn pulls air through the S.C., causing the S.C. drive gear to turn.
BrianA
77
Oct 27, 2004 06:06 PM
weymouth
56
Sep 24, 2004 09:24 AM
homer4.2
31
Jul 12, 2004 10:12 PM
BuiltToughF250
Jul 2, 2004 09:02 AM
351W76F100
Jul 2, 2003 12:05 PM
