Sponsored by: Auxito
'97 Cruise Contol Problem
Old Apr 25, 2004 | 08:03 PM
blueflaf150's Avatar
blueflaf150
The buttons on my steering wheel all of a sudden don't engage the cruise control, any suggestions/ideas??? Thanks,
Old Apr 25, 2004 | 08:25 PM
AegisSailor's Avatar
AegisSailor
I've got a problem with my brake / clutch switchr right now. You might check the alignment on yours.
Old Apr 25, 2004 | 09:30 PM
Racerguy's Avatar
Racerguy
If you snoop around in here a bit you'll find lots of posts about cruise control not working.
Lately I've seen quite a few bad brake pressure switches on the brake master cylinder and bad clocksprings. The clockspring or "airbag sliding contact" is the piece that electrically connects the steering column to the steering wheel.
And along the lines of what Roger said, make sure your brakes lights are working. If they dont work your cruise probably wont either.
Old Apr 26, 2004 | 04:37 PM
blueflaf150
Thanks for the info,,,, will try these along with more searching. Appreciate the help
Old Apr 29, 2004 | 08:58 PM
blueflaf150
Thumbs up Thanks
Well, the Forum comes through. Today I stopped at the local Ford dealer and picked up the cruise control switch that screws in adjacent to the master cylinder. As the guy at the parts counter said, the toughest part of the replacement will be leaning over the fender!!! For anyone else needing the solution the part # is F3TZ9F924BB, $33 RETAIL. A 9/16th and about 35 seconds and I was back in business. Thanks all!
Old Apr 29, 2004 | 09:04 PM
Racerguy's Avatar
Racerguy
Thanks for letting us know what fixed it
njstevens
Oct 1, 2021 09:41 PM
Ourobos
13
Dec 2, 2012 12:10 PM
nateairman
Aug 28, 2012 09:52 PM
mrwrench
Oct 19, 2009 01:25 PM
Vampiro
Jul 5, 2002 07:39 PM
